Wenlong
Can the temperature be considered as boundary conditions?
> If yes. Is dynamic effect dominant?
                                 ----> If yes, then choose transient structural or Explicit dynamics
                                 ----> If no, then do a Static structural.
> If no, is the plate heated first, and loaded after the temperature gets stable?
> If yes, then do a steady-state thermal analysis, then transfer the temperature distribution result to a static structure analysis or transient structural analysis.
> If no, which also means if the plate is loaded while being heated up (heat has not become steady while loading), then a coupled thermal-structural analysis may be necessary. I think alternatively, you can do a transient thermal analysis, then transfer the result data to a static or transient analysis, providing that your structural deformation won't influence the heat transfer speed.
Wenlong
