So your installation is probably fine. It's just the issue with shortcut
Browse to your ANSYS installation directory (default) C:Program FilesANSYS IncANSYS Studentv201
then, right click on productconfig.exe and 'run as administrator'
select Configure Products and make sure you select all products on the list and hit next.
Does this make any difference with the shortcut ?
