You can refer to the batch command from Chapter 4 of this guide
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_dan/dan_config.html
but it can't tell you exact command for your cluster submission because there are various job schedulers and each cluster setup is different depending on how your admin set it up. So, I would recommend to consult with your cluster admin on cluster submission command , then incorporate that with ANSYS batch solve command from the guide above.
