MJol
When I set the element order to linear the fluid seems to be attach to the structure.
The goal is to use the fluid body to model hydrostatic pressure and use the mass of the fluid in transient and spectral analysis with a modal analysis.
I have error when I do modal with the element order linear.
There is a free surface water. Should I model the air volume?
Best regards
