Hi Amin,
Please spell silicone rubber with an "e" onĀ the end.
The silicone rubber in the Engineering Data is under the Granta samples.
There is no Young's Modulus because it is a nonlinear material.
It uses a Mooney-Rivlen 2 parameter hyperelastic material model.
You can estimate the Young's modulus for low values of strain from the initial slope of the Stress-Strain curve. E = 1.8 MPa.
