April 12, 2020 at 9:54 am
Hi, Sorry for the delay, I haven't seen your answer.
as there is bearings I still want to perfom this study with several solids.
I think I have found the solution to my problem, I will show you my procedure, if you think it is correct then I'll mark this topic "solved"
step 1
open the geometry in space claim and slice each solids so there is no more than one BC per face.
Step 2
in static tructural, connect the sliced body together using "contact -->bonded"
Step 3
Apply the BC conditions (supports and forces)
Step 4
perform the simulation
Step 5
enjoy your results without anys warning messages.
I hope my explanations are clear and moreover I hope my solution is correct
