April 12, 2020 at 5:28 pm
Hi
Can you explain to me how to use the Solution Coordinate System in Explicit Dynamics? I tried to compare the results for different types of bodies (solid and Surface Body) in different types of coordinate systems (Glodal CS, Local CS and Solution CS) and got the same results. At the same time, some results (for example, Normal Strain) make sense only in the coordinate system associated with specific elements.
thanks for the help
Sincerely,
Eugene Kalentev
