PippoLomi
Hi kkanade,
thanks for your answer. But, reading your message, I don't understand how to solve my problem, simply because the surface between the two profiles is exactly what I want to obtain.
What is your suggestion? Do you think that the "Skin/Loft" command is correct for have a surface between the two 3D lines?
Thanks in Advance
