This plot shows the time history of the tip displacement of a cantilever beam when a 5 Hz sine load is applied at t=0. See how it takes time for the sine response to build up?
In general, you will not get the same response in the first cycle of a load as you will get many cycles later after the transient has died out and the steady-state vibration has been established.
