lildogz96
 Thanks, That helped. I'm working out of the Workbench 2019 book, but using 2020 R1. So what I did was I deleted the modal analysis blocks like you said, and then inserted new ones. Then I was able to drag the model from the modal analysis to the static structural. Then I right clicked on the solution in static structural and transferred the data to a new modal block. I was working on tutorial 11.1 in Finite Element Simulations with ANSYS Workbench 19.
