masud407
Hello Peter,
I am seriously confused about the modal results. Modal extraction is really easy. All I have to do is to set the bottom surface fixed. Even if setting material properties and doing the modal extraction correctly, I am getting very high natural frequencies. Is there any other thing that I can check to make sure that I am doing the modal extraction correctly?
