m.caragiuli
Just one question, why gasket suffice on only mesh element in the thickness, if generally at least two mesh elements should be created in the thickness of a solid body, even if thin?
The guide says Gaskets act to transfer the force between mating components. Don't they act as damping bodies as seals?
Thanks!
