tsiriaks
Hi Alex,
So, this 137.52.200.179 is your local machine ? i.e., you are hosting licenses on your own machine ?
If so and if there is no others pulling licenses from this machine, you can use the following trick to avoid any networking issue
Make sure all ANSYS applications are closed.
Open up the ANSYS License Management Center > click Stop
Launch the Client ANSLIC_ADMIN Utility v### with "run as administrator" -> Specify the License Server Machine -> Highlight the row in the box that you are specifying your hostname -> Edit Server Machine Specification -> in the Hostname 1 box , type 127.0.0.1 -> OK
Then, modify the content of the installed license file(s), which are those that end with .lic under (default) C:Program FilesANSYS IncShared FilesLicensinglicense_files , so that the SERVER line of each .lic file is using 127.0.0.1 instead of your IP address
From ANSYS License Management Center > click Start
Thanks,
Win
