Is your mesh inside or outside the car? If it is inside the car and you are modeling the HVAC system, please use the outside temperature as your free stream temperature. Yes, 305 K seems to be a good temperature in this case. The same goes for the external radiation temperature. This is basically your T_infinity.
Thank you.
Best,
Karthik
