killian153
You are specifying 2.5 atm at the inlet as total pressure and assume as static gauge pressure which is used only for initialization unless flow is supersonic. Report the value of total pressure at inlet and check if fits your input.
I'm really sorry for the late reply, but indeed when I plot the total pressure, I get a right and constant value. Thank you!
