Nicola1
This is te file "install" under C:Program FilesANSYS IncANSYS Student
Start Installation: gio apr 16 11:18:10 2020
Revision: 2019 R2
Platform specifics:
    Windows
Username of Installer: FreePC-PCFreePC
User Has Administrator Privileges
C:UsersFreePCAppDataLocalTempans_install_tmp5964instcore.exe -usetempdir C:UsersFreePCAppDataLocalTempans_install_tmp5964 -launchdir C:ansys -admin
Initial mount directory:
    C:ansys
Installation Directory:
Windows x64
Date verification complete...No conflicts found.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You don't need to install any prerequisites.
Reading the installation media contents - please wait.
  Extraction: C:ansysframewrkWINX64.7z ...
  Extraction: C:ansysinstcoretclCOMMON.TGZ ...
  Extraction: C:ansysinstcoretclWINX64.TGZ ...
  Extraction: C:ansyscommonWINX64.7z ...
  Extraction: C:ansyscommoninstallWINX64.7z ...
  Extraction: C:ansysconfigscommonWINX64.7z ...
  Extraction: C:ansyscpythextWINX64.7z ...
  Extraction: C:ansyscpythnewWINX64.7z ...
  Extraction: C:ansysturbogrdWINX64.7z ...
  Extraction: C:ansysconfigstgWINX64.7z ...
  Extraction: C:ansyscfxcomonWINX64.7z ...
  Extraction: C:ansysinstutilINSTUTIL.7z ...
  Extraction: C:ansysinstcoretkCOMMON.TGZ ...
  Extraction: C:ansysinstcoretkWINX64.TGZ ...
  Extraction: C:ansysconfigsclientlicensingWINX64.7z ...
  Extraction: C:ansysconfigswbWINX64.7z ...
  Extraction: C:ansyssgchartsWINX64.7z ...
  Extraction: C:ansysfwgfxWINX64.7z ...
  Extraction: C:ansysaddinsWINX64.7z ...
  Extraction: C:ansysaddincfgwbWINX64.7z ...
  Extraction: C:ansyscorewbWINX64.7z ...
  Extraction: C:ansyscadscadaisolWINX64.7z ...
  Extraction: C:ansyscadscadregistryWINX64.7z ...
  Extraction: C:ansysekmWINX64.7z ...
  Extraction: C:ansysaddincfgekmWINX64.7z ...
  Extraction: C:ansysmeshingWINX64.7z ...
  Extraction: C:ansysblademodelerWINX64.7z ...
  Extraction: C:ansysapipsrvWINX64.7z ...
  Extraction: C:ansysdesignmodelerWINX64.7z ...
  Extraction: C:ansyssyscplgWINX64.7z ...
  Extraction: C:ansysrsmWINX64.7z ...
  Extraction: C:ansysaddincfgturbosysWINX64.7z ...
  Extraction: C:ansyssecWINX64.7z ...
  Extraction: C:ansysccmWINX64.7z ...
  Extraction: C:ansyscadsacisparaWINX64.7z ...
  Extraction: C:ansysansysWINX64.7z ...
  Extraction: C:ansysvoxelWINX64.7z ...
  Extraction: C:ansysconfigsansysWINX64.7z ...
  Extraction: C:ansysaddincfgansysWINX64.7z ...
  Extraction: C:ansyssolverWINX64.7z ...
  Extraction: C:ansysaasWINX64.7z ...
  Extraction: C:ansysdataDATA.GZ ...
  Extraction: C:ansysapdlAPDL.GZ ...
  Extraction: C:ansysgeomparaWINX64.7z ...
  Extraction: C:ansysaddincfgmechWINX64.7z ...
  Extraction: C:ansysautodynWINX64.7z ...
  Extraction: C:ansysaddincfgautodynWINX64.7z ...
  Extraction: C:ansyscfxWINX64.7z ...
  Extraction: C:ansysaddincfgcfxWINX64.7z ...
  Extraction: C:ansysconfigscfxWINX64.7z ...
  Extraction: C:ansyspostWINX64.7z ...
  Extraction: C:ansyscffWINX64.7z ...
  Extraction: C:ansysfluentcWINX64.7z ...
  Extraction: C:ansysfluentsWINX64.7z ...
  Extraction: C:ansysfluentaWINX64.7z ...
  Extraction: C:ansysfluentuWINX64.7z ...
  Extraction: C:ansysfluentpWINX64.7z ...
  Extraction: C:ansysfluentmWINX64.7z ...
  Extraction: C:ansysfluent2dWINX64.7z ...
  Extraction: C:ansysfluent2ddpWINX64.7z ...
  Extraction: C:ansysfluent3dWINX64.7z ...
  Extraction: C:ansysfluent3ddpWINX64.7z ...
  Extraction: C:ansysaddincfgfluentWINX64.7z ...
  Extraction: C:ansysconfigsfluentWINX64.7z ...
  Extraction: C:ansysdistcompWINX64.7z ...
  Extraction: C:ansysaddincfgcfdpostWINX64.7z ...
  Extraction: C:ansysaviewWINX64.7z ...
  Extraction: C:ansysconfigsaviewWINX64.7z ...
  Extraction: C:ansysspaceclmWINX64.7z ...
  Extraction: C:ansysconfigsspaceclmWINX64.7z ...
  Extraction: C:ansysicemwbWINX64.7z ...
  Extraction: C:ansyselectroWINX64.7z ...
  Extraction: C:ansysecadxltrWINX64.7z ...
  Extraction: C:ansyscadsspatialiopWINX64.7z ...
  Extraction: C:ansyscadsspatialWINX64.7z ...
  Extraction: C:ansysacpWINX64.7z ...
  Extraction: C:ansysaddinsacpWINX64.7z ...
  Extraction: C:ansysconfigsacpWINX64.7z ...
  Extraction: C:ansyshlphlpviewerHLPVIEWER.7z ...
  Extraction: C:ansysconfigshelpWINX64.7z ...
  Extraction: C:ansystpWINX64.7z ...
  Extraction: C:ansystphdf5WINX64.7z ...
  Extraction: C:ansystpzlibWINX64.7z ...
  Extraction: C:ansystpjreWINX64.7z ...
  Extraction: C:ansyschemkinWINX64.7z ...
  Extraction: C:ansysconfigschemkinWINX64.7z ...
  Extraction: C:ansysforteWINX64.7z ...
  Extraction: C:ansysaddincfgforteWINX64.7z ...
  Extraction: C:ansysconfigsforteWINX64.7z ...
  Extraction: C:ansysfensapWINX64.7z ...
  Extraction: C:ansysconfigsfensapWINX64.7z ...
  Extraction: C:ansysstudentWINX64.7z ...
  Extraction: C:ansyslicenseWINX64.7z ...
RSS is disabled
Performing licensing configuration via the following command...
   "C:Program FilesANSYS IncANSYS StudentShared Filesbinwinx64tclsh.exe" "C:Program FilesANSYS IncANSYS StudentShared FilesLicensinglicadminscriptsLicAdminMain.itcl"  -silentinstallclient -release "2019 R2" -lang en-us
Licensing configuration has completed.
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigCommon.exe
Configuring ANSYS TurboGrid ...
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigTG.exe
Creating Start menu items for ANSYS client licensing ...
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigWB.exe
Running C:Program FilesANSYS IncANSYS Studentv194FrameworkbinWin64Ans.DriverSetup.exe
Running "C:Program FilesANSYS IncANSYS Studentv194RSMbinAnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for 2019 R2 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 2019 R2 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R2Remote Solve ManagerRSM Configuration 2019 R2.lnk
Creating Start Menu Shortcut for RSM 2019 R2 Job Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R2Remote Solve ManagerRSM Job Monitoring 2019 R2.lnk
Creating Start Menu Shortcut for RSM 2019 R2 Cluster Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R2Remote Solve ManagerRSM Cluster Monitoring 2019 R2.lnk
Creating Start Menu Shortcut for ARC 2019 R2 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R2Remote Solve ManagerARC Configuration 2019 R2.lnk
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigANSYS.exe
Adding write permissions for Users and Administrators group ...
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigCFX.exe
Configuring ANSYS Viewer ...
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigSpaceClaim.exe
Configuring ACP ...
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigACP.exe
Configuring Help ...
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigHelp.exe
ANSYS Internet Doc has been configured.
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigCHEMKIN.exe
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigFORTE.exe
Running C:Program FilesANSYS IncANSYS Studentv194commonfilesconfigswinx64configAnsConfigFENSAP.exe
Running "C:Program FilesANSYS IncANSYS Studentv194aisol..commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe"
Log files is C:Program FilesANSYS IncANSYS Studentv194CADConfigLogsLatestCADConfigurationMgr.log
MessageLogger.logFilePath is C:Program FilesANSYS IncANSYS Studentv194CADConfigLogsLatestCADConfigurationMgr.log
ErrorLogger.errorFilePath is C:Program FilesANSYS IncANSYS Studentv194CADConfigLogsCADConfigurationMgr.err
Prerequisites ..... Configure Success
SCDM  Workbench  PlugIn ..... Configure Success
Successfully created file associations.
Installation Complete: gio apr 16 12:02:52 2020
Thanks
