PippoLomi
Good morning sir,
I can create the hub/shroud surfces with an offset respect to the two imported 3D curve, but the clearance tip/shroud is added after this step, during meshing procedure in turbogrid.
I use the two revolved surfaces only for create the hub and shroud contour, needed for "FlowPath" definition.
Also, watching some videos, this seems to be the best method for define the contours needed in BladeEditor.
Following your suggestion, how can I draw the shroud line, starting from the 3D line of the tip imported from the .txt file?
Thank you
