Lukas14089
Hello Peter,
First thanks for your answer!
I tried to perfom the simulation with Beam connection as you suggested but an error occurs.. (I guess because of the non existing contact between the plates..)
Could you explain in detail which faces to select in the beam connection to avoid the contact between the plates?
Thanks!
Lukas
