April 19, 2020 at 3:55 pm
For solving the above problem, I took the following approach :
- 1. After installing the VS 2012 (VS11.0)
- 2. Place the following code to udf.bat
- 3 Rename udf.bat to udf.bat.ORIG
- 4. Set up Compilation Environment for UDF
I have two questions
1 How can I check that my configuration has been successfully done?
2. Is it not necessary to edit or compile the udf file in Visual studio?
If it’s not, I can edit the file in a text editor (ex notepad++) and after I use it in fluent> udf
thank you
