April 20, 2020 at 9:34 am
Yes i figured it out myself. Basically it will be stuck at 'Creating Solver Input Files' if the number of cores that you specify in the 'Solver Settings' is more then the number of cores that was specified for a particular node in the ARC. The number of cores allowed in the 'Solver settings' should be less then the number of cores set up in ARC for the node that you are going to use for the solution.
Thanks
Mohit
