Hello Wenlog
Thank you for your reply,
that didn't work well..
I am trying to find the effects of geometry at material( crack zone material model) on the denbonding fracture contacts.
I have defined 3 crack zone materials (same critical fracture Energy for Normal separation/ different maximum normal contact stress) and I have also defined three geometries ( I am using a unit cell from a hex lattice). the goal is to see with FEM how these different models compare ( through generating a load-displacement graph) - so it would be nice to see the nonlinear relationship fully go down to zero after breaking the contact ( also to compare the areas under the curve
some models converge easily others I have tried relentlessly to even get to its nonlinear behaviour ( load-displacement curve).
also one model requires me to define the elasticity of the crack zone material, which is a little strange (??)
if you have any feedback or suggestion, please let me know!
