pedrocarneiro
Thanks for your answer.
It seems more like the second option i.e. the beam doesn’t pass any moments in its end.
what i am thinking is use independent nodes in each one of the three beams and use the cerig command to connect only the degrees of freedom of translation between the three end beams nodes.
Is this different of use beam end release with the same node at each end of the three beams?
