AlexC
Hello Kalyan,
Awosome! This solved the problem.
But a following question. Does the feature that Fluent 2D uses x-axis as the symmetric axis only applies when I import the geometry from Solidworks? Because as I said before, I created the same geometry using Ansys DesignModeler (with y-axis as the symmetric axis), and there is no problem.
Thank you.
Alex
