Karthik R
Administrator
Regarding your first question - I'd recommend that you take a look at the Fluent Text Command list. Here is the link. You should be able to look into the commands necessary in the meshing mode.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_tcl/pt02.html
Here is some information regarding your second question. You should find everything about parallel meshing in the Fluent Users Guide.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/tgd_user_workflow_guided_tasks_vol_mesh_gen.html?q=parallel%20meshing
If you are looking for how to access this link, here are the instructions.
https://studentcommunity.ansys.com/thread/how-to-access-the-ansys-online-help/
I hope this helps.
Best,
Karthik
