regitasyali
I used the default reference value of area, because once I tried using the actual value, the results went below expected. I also used a different density but recalculated the results so it would match the density I'm using. I only maintained the values for the velocities.
I am using y+ = 1 and k-omega SST turbulence model.
Thank you!
