SaiD
Due to company policies, Ansys employees cannot download any attachments. Could you attach an image showing the deformed configuration and how the bolt head is not in contact with the plate any more (when external load is applied)? Could you also attach an image showing where the bolt is cut in half to apply bolt pretension? I just want to make sure that the cutting plane doesn't pass through the region where bonded contact is defined.
Sai
