tsiriaks
What is the job scheduler on this cluster ? Is it SLURM ?
If you are using SLURM you may need to unset this environment variable:
SLURM_GTIDS
before launching Workbench (you can create a wrapper for it)
If you have LD_LIBRARY_PATH environment variable set to some value, another thing to try is to append the following path to its value
/ansys_inc/v191/Framework/bin/Linux64/Mesa
For example
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/ansys_inc/v191/Framework/bin/Linux64/Mesa
