Sorry, I missed that Cylindrical Support includes Axial support (it didn't use to in older versions). However, you don't have axial support in the best way, the entire inner face is fixed which prevents Poisson's ratio expansion due to the applied bearing force.
If you put in a symmetry plane to support the axial direction, then the inner face is free to expand with Poisson's ratio effect when the bearing force is applied.
