RyMor
Hi Kaylan,
Thank you for the suggestion. However, there are two question I have about this approach:
1) By "duplicate" do you mean simply making a copy of the initial simulation through use of "Save As"? If so, I have been avoiding this approach due to the increased storage usage that would result from having duplicates of the initial simulation.
2) With that said, I do not see how this would be different from the method I mentioned initially which was giving me initialization errors? I feel that even when duplicating the simulation, error will still persist as I would still be changing the simulation settings of a simulation which has already been initialized and solved. Or are you suggesting that "duplicating" before post-processing would avoid initialization errors in the newly duplicated simulation?
Thanks,
Ryan
