engineer1010
Hi, I'm still new to ANSYS and I need help regarding column tested under cyclic load. How do I produce the ductility, partial ductility and load against displacement graph? I am analyzing a steel hollow column with a concrete fill. The boundary conditions are pinned at both ends. The strength of the steel is 349 MPa, the strength of concrete is 45.4 Mpa and 43.77 Mpa. And there is a friction between the concrete and the steel. The coefficient is 0.65.
Your help would be very much appreciated. You will be a life saver. Thanks in advance.
