Karthik R
Administrator
If you are solving this on the Mechanical Solver, then you should have a table appear to the bottom right corner of the screen when you select the load. There are several rows and columns there. The idea is to go in and populate the entries there. You should be input your entires there.
I hope this helps.
Thanks.
Karthik
