Karthik R
Administrator
Is your momentum source an analytical expression? If so, could you please type it out here?
Okay, so the continuity jumps. Does it converge every single time-step after the spike? Could you please reduce the time-step after you add the source term and increase the number of iterations to see if you are able to obtain a converged solution every single time-step?
Thanks.
Karthik
