clarababymangalath
oh okay.... so the scenario is, suppose a filament is added into a Panel for example in FRP, then it is assumed that around this filament a layer generates called interface.... it is yet to be characterized. So some studies were done and this interphase was then modelled as springs of zero length connecting node to node at the contact surface. They had used other softwares in this case. With ansys I will have to work with just friction it seems
