e19m5714
Thank you for the inquiry sir.
The model used is Multiphase—Volume of fluid
Materials used are:
Primary phase—sir
Secondary phase—water
Boundary conditions are:
Inlet magnitude is 0.2
Gas outlet: gauge pressure—0
Pressure profile Multiplier—1
Wall:stationary—No slip
Solution methods
PISO
Momentum—second order up wind
Controls
Pressure-0.3
Density-1
Body forces-1
Momentum-0.7
Solution Initialization
I used Hybrid in the first trial and Standard in the second trial
Calculations
Methods-user specified
Time step size—0.0001
Number of time step—3000
Maximum iterations/ Time step—50
Thanks, these are some of the information but if you more please tell me and I will give you. ?
