sunaa
Hi wallygator88,
I designed a geometry in DM, parametrized it, and imported into Maxwell. While I am trying to realize parametric simulation in workbench, I am still receiving this error even I enter the parameters used in DM as design parameters in Maxwell.
Screenshot from the parametric simulation from my setup tab is attached. I am changing 'dist' parameters (from DM and Maxwell) simultaneously, but Maxwell always reads constant value. I am really appreciated if you clearly tell how you overcame the problem.
