Zakizam
Do you mean the fluent settings like this sir?
v  Setup (General)
§  Solver
·       Type                            : Pressure Based
·       Time                           : Transient
·       Gravity                        : Y: -9.81 m/s2
·       Velocity Formulation : absolute
v  Multiphase Model (VOF)
§  Number of Eulerian Phases: 2
§  Implicit Body Force
§  Vol. Fraction Parameter Options
¨     Formulation          : Explicit
¨     Vol. Fract. Cutoff : 1e-06
¨     Courant Number   : 0.25
§  Phases
·       Oil       : Primary Phases
·       Water  : Secondar Phases
§  Phases Interation
·       Surface Tension
¨     Model                                            : Continuum Surface Force
¨     Surface Tension Coefficient         : 0.05 n/m
v  Viscous Model
§  Model                                : k-epsilon (2eqn)
§  K-pesilon model               : Standard
§  Near-Wall Treatment       : Enhanced Wall Treatment
v  Materials
§  Oil
·       Density                        : 960 kg/m3
·       Viscosity                     : 0.2 kg/ms
§  Water
·       Density                        : 998.2 kg/m3
·       Viscosity                     : 0.001003 kg/ms
§  Steel
·       Density                        : 8030 kg/m3
v  Boundary Conditions
§  Oil Inlet
·       Velocity Specification Method           : Magnitude, normal to boundary
·       Velocity Magnitude                            : 0.53 m/s
·       Initial Gauge Pressure                         : 0 Pa
·       Turbulence
¨     Specification Method                   : Intensity and Viscosity Ratio
¨     Turbulent Intensity                       : 5%
¨     Turbulent Viscoisty Ratio             : 10
§  Water Inlet
·       Volume Fraction                                 : 1
·       Velocity Magnitude                            : 0.3 m/s
·       Turbulence
§  Outlet
·       Phase   : Mixture
·       Backflow Direction Specification Method     : Normal to boundary
·       Backflow Pressure Specification                   : Total Pressure
·       Gauge Pressure                                               : 0 Pa
·       Pressure Profile Multiplier                             : 1
·       Turbulence
§  Wall
·       Wall Motion                           : Stationary Wall
·       Shear Condition                      : No Slip
v  Solution
Ø  Solution Methods
§  Pressure-Velocity Coupling
·       Scheme                                               : PISO
·       Skewness Correction                          :1
·       Neighbor Correction                           :1
·       Skewness-Neighbor Coupling            : Enabled
§  Spatial Discretization
·       Gradient          : Least Squares Cell Based
·       Pressure           : PRESTO!
·       Momentum     : First Order Upwind
·       Turbulent Kinetic Energy       : First Order Upwind
·       Turbulent Dissipation Rate     : First Order Upwind
·       Transient Formulation            : First Order Implicit
§  Initialization Methods
·       Hybrid Initialization
¨     Patch         : Water, Value (1)
§  Run Calculation
·       Parameters
¨     Number of Time Steps      : 100
¨     Time Step Size (s)            : 0.001
¨     Max Iteration                    : 20
¨     Reporting Interval            : 1
¨     Profile Update Interval     : 1
