ANSYS_BBueno
Depending on the version, there may have been a separate prompt when you first launch the installer.  This prompt would display one option to install SpaceClaim, and another to install Translators.  If you did not return to the menu and install the translators, you'll see only the short list of file formats when using File > Save As.
This can be resolved by launching the installer again and clicking Translators when presented with that option.
A less likely cause is that your PC security blocked something during the installation.  If the procedure above does not resolve the issue, try reinstalling the software using Run as Administrator to launch the installer.
