tsiriaks
Just to clarify, so your stand-alone Fluent is working fine now ? You can launch, do some work, save and load just fine ?
As for WB-Fluent loading project, are you able to just launch a blank session of Workbench-Fluent without loading a project ?
Right click on the Fluent module in Workbench and select 'Properties' , then post the screenshot of this.
Open CMD Prompt and enter the following command
set
then post the output of this as well.
