tsiriaks
You can try the following but if it doesn't help, you may need to install the non-student version of ANSYS
Set the following environment variables
ANSYSLMD_LICENSE_FILE=@
ANSYSLI_SERVERS=@
ANS_FLEXLM_DISABLE_DEFLICPATH=1
Replace
by the actual hostname of the server
by the actual port number used for FlexNet (this is by default port 1055)
by the actual port number used for ANSYS Licensing Interconnect (this is by default port 2325)
