Kalyan Goparaju
You can try suppressing all the bodies, except the one that you are interested and then export it to the format you are interested in. Try the process below
1. Right click on the Hinge_Design_Domain and click Suppress
2. Right click again on Hinge_Design_Domain and click 'Invert Suppressed Body Set'. After this step you should only have the Hinge_Design_Domain active and all other bodies suppressed.
3. Go to File->Export to export the unsuppressed geometry to the required format.
Thanks,
Kalyan
