If it's already dissolved and there is no change in concentration within the domain you supply the density & viscosity.  If you're mixing two fluids then you define the values for each fluid and set a mixture where the mixture will take account of the two (or more) fluids.
Note, properties can be a function of temperature. If it boils you'll need additional models too.
