hiroki
Thank you for response, Rwoolhou.
No, I did not set anything on this simulation at all while calculating. Just in case, the LES simulation is focused on dispersion process of hydrogen jet injecting into quiescent air with high pressure from a Laval nozzle. Before specific iterations where the simulation is terminated, it was running for almost a mouth. Maybe is it a sort of memory problem?
Best regard
Hiroki
