jiaopu
Hi. thank you for your reply.
I used default mesh settings and didn't do any modifications.
Here is a list of my errors and warnings.
  • One or more surfaces or surface boundaries might not be oriented correctly.Project>Model>Geometry>Final Frame Simplified AS PART>Final Frame Simplified AS PART
  • One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date.  However, meshing might be successful on the other entities.Project>Model>Geometry>Final Frame Simplified AS PART>Final Frame Simplified AS PART
  • One or more surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology.Project>Model>Geometry>Final Frame Simplified AS PART>Final Frame Simplified AS PART
  • One or more surfaces or surface boundaries might not be oriented correctly.Project>Model>Geometry>rightCCW>rightCCW
  • One or more surfaces or surface boundaries might not be oriented correctly. Project>Model>Geometry>rightCCW>rightCCW  10:114 AM
  • One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date.  However, meshing might be successful on the other entities.Project>Model>Geometry>leftCW>leftCW
  • One or more surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology.Project>Model>Geometry>leftCW>leftCW
  • One or more surfaces or surface boundaries might not be oriented correctly.Project>Model>Geometry>leftCW>leftCW
  • Patch-conforming tetrahedral mesh failed because of duplicated faces in boundary mesh.Project>Model>Geometry>leftCW>leftCW
  • A mesh could not be generated using the current meshing options and settings.Project>Model>Mesh
