Keyur Kanade
To create a plot you will need to create a line first. You can create a line use results --> create --> line
Then you can use this line for xy plot.
For more information please check help document at
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_Solution_XY_Plot.html%23flu_ug_Solution_XY_Plot
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_Line_Rake_Surface.html%23flu_ug_Line_Rake_Surface
Also check following.
Keyur
