If the materials mix easily (eg water & dye) then it's species. If they don't (gas and liquid) then it's multiphase.
In your case if you are not looking at condensation vapour and air are a species mixture. If you use and and water-vapour you'll also find a Relative Humidity item in the post processing under species which makes getting data much easier.
