Karthik R
Administrator
If you are exporting Fluent results (File -> Export -> Solution Data), please go in and write your CDAT files from Fluent. While writing these files, please make sure you are picking the variable so you can calculate the parameters of your interest. These variables could be Surface Nusselt Number or Surface Heat Transfer Coefficient or Wall Adjacent Heat Transfer Coefficient. Please pick them appropriately, export the solution data from Fluent, read this into CFD Post, and you should have the necessary parameter.
I hope this helps.
Thanks.
Karthik
