Aniket
how are you modeling the strands? Do they have uniform crosssection? Are they modeled as beams?
If yes you can manually define contact between the line bodies and Face of the bladder, This can be bonded initially, and once that is solved you can move to frictional which will be more likely in actual case.
-Aniket
