Aniket
Once duplicated the systems would be independent of each other, what I can suggest here is have them connected with all having default materials assigned and then use the EMODIF command using a command snippet to change the material for each body in that command snippet.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v194/ans_cmd/Hlp_C_EMODIF.html
or depending on the changes in material properties and the number of materials used, you can parameterize the material properties in engineering data and change the parameters to assign different properties.
-Aniket
