I recommend you change the shape of the flat part at the bottom so it is not tangent to the large cylinder that is above it. That spike shape on the surface inevitably leads to poor element shapes or meshing problems as you can see. I recommend you move the end of the flat a short distance to the left to eliminate the tangent condition and do the same at the other end.
