hamednik
The strains are in mm/mm and yes, they go over 300%.
I took the data from previous works and have not seen the sample but I don't think it goes through necking. The material is DuPont Surlyn Ionomer, and it is quite stretchable. So in this case what material model and failure model should I use to predict failure correctly?
